Discuss Help wiring a new wall light in the DIY Electrical Advice area at ElectriciansForums.net
iguana
Hi everyone i wanted to put a new wall light in corridor with a switch, is it possible of taking the power from a light switch from other room the light switch has only got Red (Com) Black (L1) earth.
Any help much appreciated for best way to do this.
Is there a socket in the corridor? If there is, you could plug in a suitable lamp into the socket. The D-Line trunking available from Screwfix makes a neat job in some situations. You could hide the lamp flex inside such trunking.
Thanks for advice, i don't even have a socket in corrider. Looks like i will just have to leave it.
Reply to Help wiring a new wall light in the DIY Electrical Advice area at ElectriciansForums.net
Hi I want to add a light to my attic. There is a single switch on the landing that I want to change to a double switch and then use it to still...
Hi, in my bedroom i had a 2 gang dimmer that powered 2 set of 3 spot lights and also had passthrough wires to other sockets. Im changing to just...
I have 2 lights connected to 1 switch. I installed a led light fixture on one light, it had one red wire and one black wires. It was easy to match...
Hi all, I am planning to install wall lights such as these ones (LAP Bronx Outdoor Up & Down Wall Light Black - Screwfix -...
L
WIRING FOR WALL SMART SWITCH FOR CEILING FAN/LIGHT Just bought a smart wall switch for a ceiling fan/light currently connected to a single switch...
littletwinn
L
