Discuss Help !! Wiring Underfloor Heating With Central Heating in the Electric Underfloor Heating Wiring area at ElectriciansForums.net
This is my first attempt at wiring underfloor heating and i need URGENT advice if possible.
The attached diagram is how wired. 2 zone valves, first for central heating with its own stat, second for UFH with three actuators. Actuator 1 is for bathroom with one stat and actuators 2 and 3 are together on bedroom with stat.
Question - FCU is supply at manifold and wiring centre and is only supply in with isolator at boiler. Is this ok or should I have a seperate supply fcu for boiler?
Question - If actuators are called by bedroom stat which then call zone valve will i have back feed on actutor for bathroom?
Question - Volt free contacts on stats so is wiring ok as shown?
Your help with this would be greatly appreciated and please feel free to question my drawing etc if I need to clarify.
Reply to Help !! Wiring Underfloor Heating With Central Heating in the Electric Underfloor Heating Wiring area at ElectriciansForums.net
Hi all, taken on a new build project and they have quite a large property with three separate manifolds. I have wired before with one manifold but...
Up until now I have steered clear of heating systems. I now have quite a bit of work with a builder and will be expected to deal with the...
I've pretty much sussed out the wiring for the radiators and underfloor heating, thanks to help from the forum. I do have one more question...
I have not had to do the wiring for a wet underfloor heating system before. I think I started a thread fairly recently and had some very good...
Hello Guys, I was wondering if any of you nice chaps could lend me some advice. So I have an open vented heating system with a 3 port valve...
