Discuss Help with 11 Pin Relay in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
O
Ohm From Ohm
I have an 11 pin relay and base (Relpol R15-2013-23-5230) on which I need to switch 2 separate areas individually so that if either area is energised it prevents the other area being energised. The numbering on the base is as follows L to R.
Top Row 9/34 - 8/32 - 7/24 - 5/22 - 3/14 - 4/12
Bottom Row 10/A2 - 11/31 - 6/21 - 1/11 - 2/A1
Thanks in advance.
well. 10 and 2 are your coil. use a meter to find out what is open/closed when de-energised the energise and see what goes closed/open.
Reply to Help with 11 Pin Relay in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
Hi, I purchased a relay and relay base in order to control my doorbell whilst using a Nest Hello: the Nest product takes 24V, whereas the...
J
Hey everybody! I am working with a camera sensor with a very poor documentation. Right now i have it all wire correctly to my sensor but i wish...
johnblacke
J
Afternoon in the middle of doing my 1st quote for a com/ind setup- bit out of my domestic comfort zone etc! it is for additional power in...
Evening all, This is a ridiculously long thread, so I dont expect anyone to read it all so I think I'm just looking to see if I'm in the right...
4K
1 Marvo 47 2 Dan - can probably ignore mine, most are automated I think 46 3 uksparks 23 4 Murdoch 22 5 NickD 20 6 Sintra 19 7 MDJ 17...
