Discuss Help with a light fixture!!! Please in the DIY Electrical Advice area at ElectriciansForums.net
TOM2425
Hey good afternoon guys.
I have a question about the wiring of a light fixture in my house. There was an older light here that is controlled by two different switches(one located in the hallway and one located in the bedroom.) I removed the old fixture and this was how the wiring was. Using my voltage tester I know that one of the white is hot when the switches are turned on and the The other is neutral. My concern is doesn’t both incoming cables have to have a dedicated neutral?? I don’t want to just reword a new light switch the same way as this if it is dangerous. Any help would be greatly appreciated!!
It is probably fine as the white is being used as the switch hot.
Reply to Help with a light fixture!!! Please in the DIY Electrical Advice area at ElectriciansForums.net
Replacing a light fixture in an older home. The ceiling box has two cables, each with a hot and a neutral (photo attached). The old fixture had...
I have 2 lights connected to 1 switch. I installed a led light fixture on one light, it had one red wire and one black wires. It was easy to match...
I am adding a light fixture in a room I am restoring in my 160 yo house. I have ran a new 12-2 w/ground wire from the ceiling box to a junction...
Led light fixture went dim. I replaced it with a new fixture and it won’t power on. I have 120v with a multimeter at the wire. When I wire up the...
