Discuss Help with breaker amp calculation in the Australia area at ElectriciansForums.net
T
ta-electrical
Hi, i need to know whether my calculation is correct.
I have 4 x 2.2kW Motors (3-phase) , i have a miniture 32 Amp breaker (Type D) but according to my calculation i require a 40 Amp breaker.
This is how i calculated it: 8800/(400x1.732) = 12.7 Amps per phase ---> 12.7x3 = 38 Amps
Was my calculation correct? If yes, will i require 6mm cable for this?
Thanks in advance.
Im asuming that you have this on a three phase supply so what you do require is a tripple pole C Type , this also depends wether you can reach the maximum permitted for a C type MCB on the circuit you are using it on
Reply to Help with breaker amp calculation in the Australia area at ElectriciansForums.net
Hello, I am hoping this is in the correct forum. To start, I acquired a film processing machine that runs on 3 phase. Now before getting the...
When I joined this forum a decade or so back, there was a discussion going on about a welder that was connected with a 3-core cable to L1, L2 and...
I thought that I posted this in the DIY part of the forum but I believe I did not. I am sorry about that. I put in a 10' x 20' metal shed about...
HI, I have a small shop space with single phase run to a 100amp breaker main, and I bought a few items such as a welder, plasma cutter and a...
I have a 230 Volt single-phase circuit with a 100 Amp cutout fuse and a 100 Amp MCB switch, so the supply is rated at 23 kVA. Only about 13% of...
6K
