Discuss Help with correct material in the UK Electrical Forum area at ElectriciansForums.net
Morning Everyone,
Wonder if anyone can help advise.
I am soldering multiple out rated IP67 led strips. They will be going outside.
When I cut them, I need to seal them .
I believe I need a non conductive silicone sealent (clear). And also a sealent which won't damage or corrode the PCB.
Any ideas what's best to use, Googled it and seems hard to get a straight answer
Chris
Thanks for the replies.
Glue gun, goes hard so can crack and harm the waterproof rating.
Glue filled heat shrink is ok, but can look untidy.
We have end caps which push on, and all we need to do is plug the hole before the end cap goes on with silicone glue. But concened it might conduct electric or corrode the PCB. Is this right?
Or are there different types of silicone which won't.
Reply to Help with correct material in the UK Electrical Forum area at ElectriciansForums.net
After my recent, first foray into LED strips, I now find myself needing to repair a pcb where a copper contact has come adrift from what appears...
Hi everyone We have some 10mm PCB RGBCCT strips (6 terminals/wires) being installed in the kitchen under the worktops However electrician is...
Hi fellow sparks, I've just started out on my own so I'm spending a lot of my time trying to find out the correct way of doing things of...
Good morning guys, I bought this neon sign for my cinema room to put above my arcade machines. I have the cinema controlled by Google voice...
Can I use multiple GU10 led lamps with their own PIR sensors in the same room? I have a row of existing lamps 600mm apart in a straight line & I...
