Discuss Help with fitting an LED commercial ceiling strip light in the UK Electrical Forum area at ElectriciansForums.net
Morning all
I'm hoping for some help and hopefully not too much abuse
I have a strip light that went down at the bakery so bought a replacement...different brand but assumed it was fine.
All except I am an idiot and didn't check whether it was an emergency light or not (the one I am replacing is).
Now because the box is opened and because it's now partially fitted I would like to use it at least for next couple of days until I source a replacement that is emergency.
Issue is wiring isn't a straight swap and as you can guess I am not an electrician.
The new one looks like this, just a straight neutral, live and earth. The instructions say to put the switched live in the live connector.20190425_025555.jpg
However the old one is currently wired like this:
And as you can see it has 2 live terminals...presumably one for the switched and one for the permanent.
So my question is can I make my new light fitting work and if so how do I wire it?
Thank you so much to anyone that takes the time to help with this.
Duncan
It will function once you know which of the L conductors are the switch supply and the other made safe until a different fitting is obtained. I could hazard a guess but that is not the way to proceed. The circuit needs testing to verify the purpose of the conductors.
connect the 2 brown L wires that are already together (permanent Lin and Lout)in a choc block, do not connect into the light terminal strip. then you have a single brown (switched L), 2 blue (N) and 2 cpc's (Gn/Y). the bold text is the supply to the light,
You will need to do all that work with main circuit breaker switched off..
Even though the light is switched off at the wall the brown wires will still be live..
Do you have something to test for voltage?
Reply to Help with fitting an LED commercial ceiling strip light in the UK Electrical Forum area at ElectriciansForums.net
Hi Guys I've fitted a few emergency lighting circuits to both domestic and commercial installs before, I've come across one I can't get my head...
I have three Aurora Fluorescent linkable (linked) under cabinet 'strip' lights (c.21cm each) under the kitchen cabinets and over the sink area...
I have a strip light in the kitchen operated from a single switch. I want to replace it with a straight bar 4 spot array. There are three supply...
As the title says. But then I cut off a jst connection off one of the light strips and I can't get them to work together... the one strip is plug...
I have 2 lights connected to 1 switch. I installed a led light fixture on one light, it had one red wire and one black wires. It was easy to match...
