Discuss Help with replacing light switch please in the DIY Electrical Advice area at ElectriciansForums.net
I was hoping to replace a 4-gang light switch with 2 Koogeek smart 2-gang switches.
I removed the front of my existing light switch and discovered there are 7 wires coming into it and what google tells me might be a 'loop in switch'? o_O
I drew a picture:
The two new light switches have fewer holes :( :
Is it possible to connect my lights to these?
Thanks!
I doubt there is a neutral present for your existing wiring, the blue conductor is almost certainly a switch live conductor so it is not going to function.
How are you gonna fit 2 x 1 gang switch plates onto a 2 gang back box? Neat drawing btw
Bugger. I was hoping the blue wire was a neutral.
Enlarging the hole in the wall I can manage, but the wiring behind the switch is too complicated for me :0
Ok thanks again guys, I've been doing more reading.
I could use two Xiaomi Aqara switches instead, they have no neutral.
How would I wire my existing 7 wires to two of these?
if you have several black conductors giong into a choc block and not connected to the switches, then they will be neutrals.the backbox can be replaced with one that allows for 2 single faceplates. however, i recommend getting a local sparks to fit this for you.less chance of it going bang. whereaboults are you one of us may be close. it's not a wallet emptying cost to have it done professionally.
“Blacks are connected together”... read the small print.
Cable 2 appears to be a live feed. 1 and 3 are switch wires to lights.
The other side is a little more complicated, and appears to be using a different live feed? Can you confirm? (Did you have to isolate 2 circuits to make all this safe?)
If so, then all your blacks connected together from both circuits is what is known as a “borrowed” neutral and needs to be fixed.
Agree that you may need professional help with this.
Yes, I have to turn off two circuit breakers to disable all the lights on this switch. (It's a kitchen, which was extended before I bought the house).
So I might have neutral wires? That's encouraging! I just packed up the Koogeek switches for return yesterday but I haven't posted them yet! Also haven't yet ordered the Aqara switches although they are sitting in my shopping basket.
Thanks for all the help. I was hoping to be able to do this myself but looking at the existing switch I just don't understand how the circuit works. It looks like it should just catch fire! I will take everyone's advice and find an electrician. I will ask here first! (I'm a few miles outside Cambridge)
I'll have a think about it. I was going to go with Koogeek for Apple's HomeKit but yesterday I set up some extra hardware which means I can now use non-Homekit stuff as well.
Not between L1 and L2, no.
I checked again, I made an omission earlier. The 6 black wires from Wires 1-6 are connected together in bunches of 3. The 6 yellow/green wires are all connected together.
I took a photo this time:
Can you confirm which if any of those switches is or was a 2 way?
The wiring on the 3rd switch is wired as though it were once a 2 way but has since been changed, the 4th switch has strange wiring, it looks like those 2 wires on L1 could have gone to Common, so no need for the strap.
Reply to Help with replacing light switch please in the DIY Electrical Advice area at ElectriciansForums.net
Hi, I’m looking to install 3 meross smart switches for 3 lights: entrance switch: only 1 gang but 3 way switch bedroom switch: 2 gang (1 is 1...
Hi I want to add a light to my attic. There is a single switch on the landing that I want to change to a double switch and then use it to still...
Hi All, I am looking to install a Quinetic double gang in line receiver switch (QURS2W) in my hallway on the ground floor to control the lights...
L
WIRING FOR WALL SMART SWITCH FOR CEILING FAN/LIGHT Just bought a smart wall switch for a ceiling fan/light currently connected to a single switch...
littletwinn
L
