Discuss Help with solar powered LED floodlight in the Solar PV Forum | Solar Panels Forum area at ElectriciansForums.net
Evening all,
Firstly I have zero experience working with solar installations so hopefully somebody can help me out?....
Ive been asked by a farmer friend if I can install a floodlight for security/deterrent reasons on a remote storage shed and im guessing solar is the only option as no power on the site.
Id like to know what specification of kit is required to power minimum 50w>max 100w LED light?
Ideally either PIR or timer activated to save on battery consumption.
Also roughly what could you expect to pay for the materials only?
You don't need a big solar module and a big battery. If you are using a sensor based light then a small battery is fine. It then needs to be kept fully charged on an average winters day. I suggest for a 50watt sensor floodlight set to activate for 30 seconds a time you have a 40-50w module with a 8ah battery. The solar charger can be a small 5amp. Do not use LCD display as this is useless and uses power all the time. I have a 40 watt gate lighting using 50wp and 2 small sealed batteries and it has been running 2 years. The battery and controller are in a plastic enclosure on the pole under the module. You need to make sure the sensor is not picking up foxes etc. It is a deterrent not a source of light for thieves to work by. A 30 watt light will illuminate a very large area and save a large chunk of battery power.
Reply to Help with solar powered LED floodlight in the Solar PV Forum | Solar Panels Forum area at ElectriciansForums.net
Electrical2Go - Home Security: Using Floodlights, CCTV, and Door Entry Systems In an era where technology is advancing rapidly, home security has...
Apologies for the complexity of this question, but there’s no easy way to explain it. This is a remote Norfolk house and workshops, developed...
Not sure if this is related to solar panels but.. I have an Ampy 5258k meter next to the consumer unit. Before I had solar panels installed...
8K
Hi Guys Later this year I want to do a solar power and or wind power installation into my allotlment shed. I've watched tonnes of YouTube videos...
