Discuss Help with wiring new light switch in the DIY Electrical Advice area at ElectriciansForums.net
nellystew
Hi
I'm replacing my light switches with new ones, but am a bit confused on the wiring.
The current switch has three terminals labelled 1, 2 and 3, but the new switch has Com, 1 way and 2 way.
https://i.Upload the image directly to the thread.com/yVtxmy8l.jpg
Is there a straight 1 to 1 match for the 3 terminals?
The earth is currently connected to the back box, but as I'm fitting a metal switch I'm going to wire it directly to the metal front plate.
I don't need to run a new earth from the front plate back to the back box as well do I?
Thanks.
Assuming that is two way switching the single red into common, then keep the others as they are into the other terminals doesn't matter which way around. Yes just connect the earth to the front plate.
Reply to Help with wiring new light switch in the DIY Electrical Advice area at ElectriciansForums.net
Hi, I’m looking to install 3 meross smart switches for 3 lights: entrance switch: only 1 gang but 3 way switch bedroom switch: 2 gang (1 is 1...
Hi I want to add a light to my attic. There is a single switch on the landing that I want to change to a double switch and then use it to still...
I have 2 lights connected to 1 switch. I installed a led light fixture on one light, it had one red wire and one black wires. It was easy to match...
Hi, I have a single light switch, wired like this.. the 2 wires in com, with a always live wire coming to the switch, and then wire going out to...
