Discuss Henley block alternative? in the UK Electrical Forum area at ElectriciansForums.net
dougquade
Hello peoples ?
I am installing an additional consumer unit to an installation. I’m going to stack them one above the other, normally I would use the henley blocks but I was wondering if there is an alternate solution to this? Is there any way Split the supply cables within the CU’s?
I know you can get double stacked boards but they are pricey
Are you fitting the same make board? as if it fits with using bushes and lockrings you could use tri rated tails some manufacturers make joining kits.
Reply to Henley block alternative? in the UK Electrical Forum area at ElectriciansForums.net
Afternoon All, Just pricing up a job and thought I'd pick your brains. Quick run-down, Block of Flats with an underground car park. In the...
Hi guys, could someone help with the following please? The scenario is: Domestic property supplied via three phase (with a 3P main DB, NO SPD)...
Hi everyone, a landlord is converting a house into two flats and wants a separate consumer unit for both flats upstairs and downstairs. He also...
Hi all. I have been asked to take over a job an electrician has started, and has moved abroad. The house is a big mansion, with a 3PH supply...
4K
In the UK, It is said that the neutral wire is connected to ground/earth wire along the way back to the substation. Ive inherited a setup where...
