Discuss Hi and thanks for having me. Can I wire an Au plug to this fan? in the UK Electrical Forum area at ElectriciansForums.net
Kinda was hoodwinked on Ebay. Pic had black wire, taped and end hidden. No mention of no plug. I guess you get what you pay for. Liv'n'learn. Anyway, I can return it, but was wondering if I can simply wire it to a plug and use it. Tried Google but no mention of Fans with 2 red wires. Apreciate any advice, Cheers.20191117_213828.jpg
Not sure of the rules in Aus but those wires only look single insulated and it is not clear if it needs an earth. From its country of origin I am none too sure I would use it.
You could connect a plug and it would work, but whether the result would comply with any applicable regulations is highly doubtful.
Yeah definitely wouldn't comply just whacking a plug on the end. Doesn't inspire confidence that the rest of the unit would meet Australian Standards either.
If you're in western Sydney I could take a look at it and see if a new plug and lead could be fitted, best I can offer from here.
Cheers. Apreciate it. Binning it and grabing a "better" fan.
[automerge]1574076840[/automerge]
In Australia you cannot put a plug on anything unless you have at minimum a restricted electrical licence, are registered and insured.
Yeah, not going there. Grabing another one from a more reputable retailer. Thanks.
[automerge]1574077015[/automerge]
Throw that Chinese ---- in the bin cobber.
Might "throw" it at the sellers head. My bad for going the cheap option. Ya' live ya' learn.
[automerge]1574077224[/automerge]
Don't worry, 2 red wires indicates that you got the delux model.
If you were enthusiastic as me, you would already have a plug on it and sitting in front of that sweet cool air.
I'm here if you need me
Aint the red ones supposed to be faster. Wait til I paint some stripes on her. then you'll see some serious ----. Thanks though. Years ago i would have thrown caution to the wind. A tad wiser these days.
I bought something similar in the UK, it was made in Poland by a company called Dospel. It had no wires - needed hard-wiring into the cable from the switch which was quite fiddly with 1.5mm twin & earth.
It was rated 220/230V but IMO these things always have loads of contingency in the ratings so I don't think it will blow up at 240V. Has twice the air throughput of yours and is still very quiet.
Reply to Hi and thanks for having me. Can I wire an Au plug to this fan? in the UK Electrical Forum area at ElectriciansForums.net
I had to replace a surface plug socket box after the plasterer destroyed the old stuff. It has black, red and earth wire, 3 of each and look...
Hi all, I did train as an electrician but never worked as one so my experience is limited and ive not done anything for a while now. I have an...
Extractor fan is currently wired to light switch. Plan to remove this wiring and wire to timer switch will have new cable run and new wall box...
I posted yesterday and then thought I had it figured so I edited post and thankfully, a moderator then deleted it. I apologize for making work...
I've got an old furnace fan I kept the last time mine was replaced. I'd like to use it for various purposes. It has a red, black, yellow and...
