Discuss Hi guys, has anyone got a fix for clipsal saturn series mech on a 2 way light staying dim when off? in the The Welcome Forum area at ElectriciansForums.net
I have run new cables, segregated the SDI cable running back, so the LED will switch independently and have also installed a capacitor, since I was informed that would be a fix but it bursts light. The picture shows bottom mech with the switch on and bottom mech with the switch off. Thanks so much in advance.
  • Hi guys, has anyone got a fix for clipsal saturn series mech on a 2 way light staying dim when off? 20211020_113457 - EletriciansForums.net
littlespark
Ah. Ok. You may be better asking on an Oz forum then.
We’re an international forum. Didn’t you get the memo? ?
I’m sure we have other members from down under… just wait and see.
A two way circuit is a two way circuit wherever you are in the world, (except US, where it’s a 3-way) so it might be the old induced voltage with cables running together.
I would have to look up specs of the fitting, as I don’t know what the SDI cable does.
OP
C
The SDI is just so when you turn the light on the LED around the mech is on.
Dan
Staff member
Admin
Hi
Thanks for joining our forum.
Have you managed to fix your issue?
Reply to Hi guys, has anyone got a fix for clipsal saturn series mech on a 2 way light staying dim when off? in the The Welcome Forum area at ElectriciansForums.net
I have a fan light fixture which I wired more than a year ago. It has three dimmable LED light bulbs on the bottom which recently started...
Hi there. I'm building a house and need some help with the LED lighting design. Lots of experience wiring things, some experience using LEDs (did...
Hello, after changing all the light switches in my house from old to modern, I am now left with the tricky one that I can't work out. - I have a...
Hi, I'm looking for something rather specific and I don't know if it exists or not. I'm trying to plan a system that allows the lighting...
T
Hi I'm new here so be gentle. I have a reasonable knowledge of electrics and did an essential electrics course and my 17th Ed a few years ago. I...
the glory years
T
New Posts (Please Reply)
