Discuss Hi guys, has anyone got a fix for clipsal saturn series mech on a 2 way light staying dim when off? in the The Welcome Forum area at ElectriciansForums.net
I have run new cables, segregated the SDI cable running back, so the LED will switch independently and have also installed a capacitor, since I was informed that would be a fix but it bursts light. The picture shows bottom mech with the switch on and bottom mech with the switch off. Thanks so much in advance.
Ah. Ok. You may be better asking on an Oz forum then.
We’re an international forum. Didn’t you get the memo? ?
I’m sure we have other members from down under… just wait and see.
A two way circuit is a two way circuit wherever you are in the world, (except US, where it’s a 3-way) so it might be the old induced voltage with cables running together.
I would have to look up specs of the fitting, as I don’t know what the SDI cable does.
The SDI is just so when you turn the light on the LED around the mech is on.
Hi
Thanks for joining our forum.
Have you managed to fix your issue?
Reply to Hi guys, has anyone got a fix for clipsal saturn series mech on a 2 way light staying dim when off? in the The Welcome Forum area at ElectriciansForums.net
Hi, I am looking to convert a 2 way light into just control by single switch. I have searched and looked for similar questions here, and found a...
Sorry for the long first post, I wanted to be as thorough as possible. On my landing I have a 2-way switch setup, one of which is 3-gang, one of...
Morning All I recently completed my first re wire and board change, (with help from the owner who is a gas fitter and plumper, who works with my...
Hello, DIYer and first time poster here. Recently bought a house built in 1925, and am gradually working through adding and replacing the wiring...
