Discuss Hi, i require some help in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
question is a bit vague. as a starter you use BS7671 regs. using tables in there to select cables for current carrying capacity and volt drop and all other de-rating factors. once installed, you then carry out tests to ensure that the installation is compliant.
And again, plus, what course are you studying for? these questions you are asking, seem typical of examination questions.question is a bit vague. as a starter you use BS7671 regs. using tables in there to select cables for current carrying capacity and volt drop. once installed, you the n carry out tests to ensure that the installation is compliant.
Reply to Hi, i require some help in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
