Discuss Hi, new member in need of air source heat pump help in the The Welcome Forum area at ElectriciansForums.net
Hi
Just signed up to see if anyone can point me in the right direction with air source heat pump for my above ground pool. It stopped working a few weeks ago and I thought the display unit had gone. However I've tried to replace it but that doesn't power up either. I've had the top off it and worked out that something still works because if manually pressed down the HVAC contactor (not sure if I should be doing this) it fires up. I was wondering if something else had failed and was preventing the power getting to the display unit. If it helps, it's an obsolete competition heat pump.
Any help would be very much appreciated.
Chris
Hi Chris and Welcome to the Forum !
Have you got the installation booklet for the heat pump? Or can you tell us more about make model and posting a pic would be helpful.
With the display dead, likely the controller won't fire up the contactor etc. And you are right, not a good idea to do that manually as it will have safety cutouts ... With the unit fully disconnected from power, perhaps have a look on the controller board for any fuses?
Hi
Thanks for the reply. I'm assuming the controller board is the circuit board inside the display panel? If so I can't see any fuses in there. Here are some pics of it.
Is the system short of refrigerant?
Well a low refrigerant charge would cause the system not to work, without knowledge of the system and it's control circuitry, it would be difficult to say, My response was a reaction to a question, and that's all.
Reply to Hi, new member in need of air source heat pump help in the The Welcome Forum area at ElectriciansForums.net
Hi all, I've noticed that my UFH pump is not always turning on as soon as the stat & valve calls for heat. This results in hot water passing...
We have just completed a self build, and heating system is Air Source Heat Pump, unvented HW cylinder, Buffet Tank, all Vaillant equipment. The...
My mother moved into her three bed home in 1960 and it had underfloor heating in the living room. I remember we used it when I was growing up in...
Hi guys We are due to undertake a new build install where they are using air source. Its the first air source I have installed so need a bit of...
Good evening, I have recently moved into a new home and I am having problems with the MCB/RCD tripping (Mem M6 Type 3 - 30mA). It intermittently...
