G
Guest22
I have a question in terms in conduit, In conduit you use all the same size conductors in a circuit for a ring for instance, 2.5mm2 Line, 2.5mm2 Neutral and 2.5mm2 CPC.
Question, in T&E 2.5mm2 you have both line and neutral but CPC 1.5mm2, correct but, would it not be under regs to wire a 32 Amp radial in PVC conduit 4mm neutral and line, and a smaller CSA CPC?
Just a question
Cheers
Just a question
Cheers
