Hi
Discuss Hi in the The Welcome Forum area at ElectriciansForums.net
Hi Cunny and welcome to the forums.Always something i would like to do, is work in the middle east:D
Quick introduction, working out in middle east at present for US contractor as sparx. Interesting environment, dealing with UK & US regs, quite a challenge.
Is there much difference between the UK and US regs
Apart from the obvious with the differences in US & UK regulations, the main thing I have noticed is that the US code tells you what to do but not why you are doing it, 7671 tells you why you have to do something, but not how to do it.
hi and welcome to the crew! ( i bring da street vibes) is it true that the US use no earth and a 110V supply? if it is what supply are you using?
No, the USA definitely earth their systems (grounding). They use different words, that mean the same in the UK. Their voltage is 120v 1P, however they use lots of different voltages, depending on the star/delta windings of the transformers. They adopt a 5 wire system like us (TN-S) & will use a 4 wire system (TN-C) where they build their 5th conductor themselves (put the N-PE link in at the Panel, done by the sparx, not the utilities) to make it TN-C-S. they arent so happy with our TT, and SWA, tending to prefer trunking & conduit for everything. 1 of The biggest difference I have seen, is the use of wire nuts (the old dogs $%%B) instead of connector blocks in ligh fittings, & they dont test like we do, hence UK sparx out here. Plus the systems we are working on are 230/400, which is our bag. All in all they are good guys to work with, albeit a little 'different'.
Reply to Hi in the The Welcome Forum area at ElectriciansForums.net
Hi all, just posting my mandatory introduction thread! I'm in my early 30s and not enjoying my desk job and I'm considering chucking it all away...
An Invitation to Retired Electricians anywhere except the UK with Four Days a Month for a Niche Opportunity That Can Earn 15K a Year. There are...
Hi, I am involved in a local charity which is fundraising to restore a local pub into a community hub (and also a pub). The pub which is The Hop...
Hi All Happy new year to all! First post but long timer lurker, so thanks for all the previous help! Just wanted to clarify something I have...
Hi, sorry if this is the wrong place to ask, I am wondering about becoming an electrician of some form or another and thought to come to an...
