Discuss High and Low Voltage Wiring in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
realistically, you know the cables are there. you're not a plumber, so in the real world, it's not too big a deal.
With your Electrical Installation Certificate there should be a page titled Schedule of Inspections, essentially a tick sheet.
On here you should find a comment Segregation/separation of Band I (ELV) and Band II (LV) circuits, and electrical and non-electrical services, if this has been ticked then this claim is incorrect.
Another comment will state Cables concealed under floors, above ceilings or in walls/partitions, adequately protected against damage, again if this has been ticked then this claim is incorrect.
Reply to High and Low Voltage Wiring in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
Hi everyone, When checking my consumer unit voltages with the full board off, I stumbled across something head scratching. Measuring the feed...
Extremely low voltage on 120v line Hi, I’m not an electrician but my home has 20 amp breaker that has only one outdoor outlet on it with a GFCI...
Hi, I have just had an EICR carried out and it has comeback with a few C2s. The only one I disagree with is the electrician raised as a C2 the...
Well....wiring in a 1750s thatched cottage attic, not wiring made from thatch 🤪 One we have been letting for over 20 years (as well as enjoying...
4K
A
the situation is this: 8 x 24v rgbw flood lights for a garden, each fitting has power consumption of 45w. 3 lights into a 200w driver, another 3...
