R
radiohead
Called out to a problem in a remote rural property, TNCS 100a single phase supply, overhead lines. Testing after sorting the issue my MFT flashed up a voltage of 265v L-N . Thinking the MFT was playing up I re-tested with a multi meter and got the same result. UKPN called and attended later in the day, recorded 252v, pronounced it ok and left. I returned today and got 266v on no less than 3 different meters. Also tested N/E to a temp earth rod and found no significant voltage. Ze within expected tolerance. UKPN attending again hopefully.
Any suggestions as to possible causes?
