P
philjwb
Hi,
I am upgrading one of the electric showers in my house from 8.5kW to 10.8kW and I want to check weather a higher rated RCD should be installed.
I currently have 2x 8.5kW showers, both connected with 10mm^2 cable and 40A MCB's and a single 80A/30mA Contactum RCD (B8003/2) in my Contactum consumer unit.
I have purchased a new 50A MCB, which I will use to replace the MCB for the new 10.8kW shower, but I am now concerned that the current rating of the RCD could be exceeded if both showers are used simultaneously. Should I also upgrade the RCD (eg to a Contactum 100A/30mA B10003/2)?
Any advice gratefully received.
Phil
Phil
