Discuss Hmo fire alarm in the Security Alarms, Door Entry and CCTV (Public) area at ElectriciansForums.net
T
Tapouchoke
Hi folks
I am in the process of pricing for a fire alarm job 10self-contained flats over 3 floors. A 12 zone conventional fire alarm system have proposed
LD2
System incorporating alarms in all circulation spaces
that form part of the Escape Routes, & all rooms/areas
excluding Bathrooms, Shower rooms & toilets, where a
high risk of fire exists to occupants.
I.e. smoke& sounder in hall also heat in kitchen optical smoke in lounge of each flat
Each floor of communal area Optical smoke and break glass & break glass@ exsits
As no specification has been given to me from the client
Have asked client to get full fire risk assessment on building
To you think that what I have per posed will achieve LD2 so I can certify it AS AM NICEIC CONTRACTOR AND THE NICEIC DON’T REALLGIVE MUCH ADVISE ON THIS SUBJECT
All advice appreciated
Thanks for taking time to read post
Cheers
:confused:
hi tapout
first thing i would do is contact the building inspector for his requirements.
i have just done a similar job and it included the following as required by the building inspector.
1)each flat to have normal domestic mains powered smoke/heat detectors independant from any other flat/common area.
2)common area hallway/landing etc to have dedicated fire panel
3)automatic smoke vents to common area windows that open when fire panel goes into fire mode.
4)firemans overide switch to manually open/close smoke vents next to entrance.
hth
matt
Hi.
I'd agree with Matt, mains powered battery back up domestic smokes and heats in each flat. With the communal areas a full blown addressable system with panel, call points, sounders (1 in each flat also), beacons, interfaces for any mechanical plant valves i.e gas, lift, ventillation equipment etc.
Cheers.
I spoke to fire safe recently about a job much the same as yours. They propose 4 zone panel, zone per floor (flats only). Then fourth zone to cover communal areas. This is the cheaper option as apposed to full adressable system. My local authority have no problems with this proposal.
id also go for the 4 zone conventional like johnsparks and possibly combined smoke sounders in the flats i think you have to achieve certain decibel levels at the bed heads but would have to check that
cheers folks
you need to have 75db @the bed head ,dont think you would acheeve this whith mains detectors if wasent in the room that you where sleeping
was under the immpression that a ld2 system was required for HMO propertys but went to one today and the property had as lenny described commuinals coverd by conventonal pannel with smokes and breakglasses mains smoke in hall and mains heat in kitchen it seens lke a gray area???
thanks much appricated
TapouT
I would go for a Mixed System of Conventional Panel supplying......
Communal Areas..........Optical smokes
Communal areas/Landings & exit routes...........Break Glass units
Communal areas.........Sounders
Any Communal lounges......Ionization smokes
Entrance Hall of each Flat..........Heat detector & Sounder
Each Flat.........Mains/Battery Smoke or heat alarms {interlinked inside each flat}...as required
This system gives protection from nuisance alarms for all other flats when one flat burns the toast etc...BUT gives a Full alarm to All areas via the heat detector if a fire situation occurs...
I have used this set up with minimal Nuisance activation recorded.......and happy tenants..
One word of advice though ! put it to the licensing authority first.
spark 1:)
spark 1:)
cheers mate
really helpfull
the problem with having any part of the communal fire alarm in the flats is that everyone will rush out at the same time.
i would be interested to hear the outcome tapout if you get the time to post.
cheers
cheers
What is the alternative ? phased evacuation perhaps ? not really necessary in this instance....what woud you suggest ?
Reply to Hmo fire alarm in the Security Alarms, Door Entry and CCTV (Public) area at ElectriciansForums.net
Hi all, i'm just after a definitive answer regarding a fire alarm system in a communal area/stairwell. There are call points, smoke heads &...
any BS 5839 experts know whether CO alarms should be connected to the smoke/heat alarm system ? after completing an efixx CPD it seems they should...
Hi, I'm completely rewiring a 9 bed 3 storey HMO in Jan, The fire detection required is just some linked lithium detectors in the...
I've asked a similar question before I think and we came to the conclusion that apart from new houses and HMO's etc there aren't any rules about...
Good evening! Don’t have a huge deal of experience with fire alarms but having to work on a conventional system at the minute with various...
