Discuss Hob cable outside then in in the UK Electrical Forum area at ElectriciansForums.net
Evening All another odd question (I love my customers)
There’s no 10mm or 6mm cable in their kitchen, apparently when it was wired there were all 13amp eco appliances. Anyway a new couple have bought it and want a 5 ring hob installed but the kitchen is done to a high standard so they don’t want trunking or walls chased (kitchen in single story extension. The board and job location are on the outside wall. Can I run a 6/10 mom cable through the wall outside the back inside for for the hob connections obv the cable would be aremourd or SY. Is this doable or is it a case of no can do
Basically asking can I run the cable from the board inside, through the wall clip the cable to the outside then bring it back in where the hob location is and connect up. So basically the cooker feed with run outside then back in
You can't do that with Swa mate unless you use ''ugly' gewiss boxes what a faff on.
Yeah basically I’m asking is it allowed in the rgs. To bring a cable outside then back in for an internal appliance. I could be asking could I run a cable from point a in to point b which are both inside but the cable connecting them is outside of the building
I would consider using conduit as it would look tidier than cable. If it’s a straight run black enamel looks good.
Reply to Hob cable outside then in in the UK Electrical Forum area at ElectriciansForums.net
Hi folks, DIYer here, hoping for some advice before most likely calling in a spark. I'm looking to wire in new cooker and hob (separate units)...
Howdy All, just after a 2nd opinion as i'm doubting myself. I went to a property to look at replacing the ccu, I noticed what I thought was a...
  • Locked
5K
