Discuss Hole in joist - question on span in the DIY Electrical Advice area at ElectriciansForums.net
Sloth
I need to make a hole in a floor joist - I know it needs to be within 0.25 to 0.4 x the span, and in the middle of the joist etc, but I can't find a clear answer on what the span is when there is a supporting wall in the middle. Is the span seen to be between the outer wall, and the supporting wall in the middle? Thus you have a span either side?
new build or old build?
Thanks guys.
Old 60s ex-council house. There are holes in various places, both original and added-at-some-point in the past that are very much not in places they should be. I'd rather not add any others where they shouldn't.
Remember sizing of joists is not to do with overall strength but rigidity.
you could halve the size of all the timbers in your house and it would still stay up. Just wobble a bit more... then fatigue and fall down a bit sooner than it would have if you'd left it as the designer intended.
If your hole is for one cable (say 10mm dia.)and if its in the centre go the joist it'll make no difference at all. Or rather the affect will be negligible.
I'm sure you were only exaggerating to illustrate a point, but his house would fall down fairly quickly.
If you halve the width of a beam you reduce its strength by a factor of two
If you halve the depth of a beam you reduce its strength by a factor of eight
If you halve both width and depth you reduce its strength by a factor of sixteen
Reply to Hole in joist - question on span in the DIY Electrical Advice area at ElectriciansForums.net
Hi All I wanted to ask a question about the reference method. Passing wiring through holes made at 0.2-0.4 of the joist span. The cables passes...
hello, i am just about to completely rewire a refurbished house. i have done the same to several houses in the distant past. i have just read...
Hi there - good site. Mrs wants a new socket directly below a light switch on the ground floor (says it will look neater vertically inline)...
Most of the work I do is additions and alterations in domestic properties, and other than swapping accessories and lights in new-builds for...
