Discuss Home CCTV with RJ45 inputs in the Security Alarms, Door Entry and CCTV (Public) area at ElectriciansForums.net
You need to know if the RJ45 connectors are carrying analogue video (unlikely) like the BNC connectors would. Or are IP cameras and that's a data connection.
Just saw this post, I know it's a bit late but as the other posters have said, you need to find out if it's a digital system or analogue. If it's digital then you need an NVR and if it's analogue then you need a DVR.
For the DVR you will need to fit baluns to the RJ45 plugs to give them BNC connectors. For the NVR the RJ45 plugs will fit straight in.
Reply to Home CCTV with RJ45 inputs in the Security Alarms, Door Entry and CCTV (Public) area at ElectriciansForums.net
Hi All, so I have a outdoor cctv camera that you plug in - I'm thinking of attaching this to the soffit and going into the loft from there (very...
Hi, New to the forum. I have two very specific questions, for the setup below. Setup details: Currently I have a setup with an outlet used for...
Hi, I purchased a Time twin strand bell cable with a rating of 12-30V, 2A, low voltage, not for mains use. I wish to use this for installing our...
Hi, plumber here so please be gentle (or take the p-ss ;) ), I am supposed to be installing a UV water steriliser for a customer. I have some...
Hi Guys, I'm having trouble diagnosing a fault on a customers downstairs socket ring, which only ever trips when the washing machine is used. The...
