Discuss home office supply in the UK Electrical Forum area at ElectriciansForums.net
Hi,
What size supply would you install for a kind of wendy house in the garden that's going to be used as an office for 2 or 3 people.
around 6 sockets and a double fluorescent. They'l probably be plugging in a 2kw heater at some point when it gets to winter.
Is a 32A feed on 4mm swa a bit overkill? Knock it down to a 2.5mm on a 20A? what would you do? probably not much cost difference.
Was planning on running a 16A radial socket circuit and a 6A radial for light.
Yea this is LEGIT. Part p registered. I'm more of a commercial industrial electrician though.
Good stuff.
I have found that most "home offices" actually get by quite nicely on a 13 amp supply, even with a fan heater and a couple of computers, but only you can know what the loading is likely to be.
We need to know the length of run first of all mate, to calculate volt drop, along with ccc.
Yea the runs about 20M, swa clipped direct and then buried in the ground.
I'm thinking there's probably going to be about 3 computers, and other general office stationary printer, photocopier etc then a 2kw heater.
For what its worth theres nothing like running a supply then finding out its too small latter, for the lil extra cost go with a 32-40 Amp supply. You may find it really cold in the winter and need more heaters. look into what earthing system your gona use. TT the office, or export the house earth..
In this situation, I'd probably be inclined to agree with Edd. 32A supply.
Any metalwork entering the office (pipework/steelwork etc.) ?
Sounds like a plan.
So, as you will be using lighting in there, work out what size cable you will need for your 20M run, to allow for 32A supply with no more than a 3% vd.
You can't beat a wired internet connection, even if the internet connection is good there is not garunteeing the wireless transmitter in the router is decent. Virgin Superhub comes to mind!
Sent from my GT-I9300 using Tapatalk 2
It's people like you that are trying to take the food out of our bairns mouth ............there we are hard working leccy's trying to earn a honest crust and recommend earning a few pennies by installing some data/telephone cable and your suggesting wireless ..................I don't know
:teeth_smile::teeth_smile:
Ha ha, just testing the water! In truth, I'd be running a telephone/data cable and a Sky+ feed if it was my home 'office' ;)
ah yea it would have to be a 6mm for a 32A supply to be under 6.9v. i'l re measure the run perhaps i was being a bit generous, it might be more like 15M.
Don't forget that your total distance is measured from the intake, not the hole in the wall where the cables comes out into God's fresh air.
6mm 3 core IMO. That will mean you can boil a kettle and have the heating on at the same time!
Reply to home office supply in the UK Electrical Forum area at ElectriciansForums.net
I'm looking at a vending hot drinks machine 2.9kW that has a thermostatically controlled hot water tank permanently attached to a water supply...
Hi all Now being upfront I am not a sparks. I am about to have some work done by a friend (certified) and as he is doing me a favour I want to as...
A friend of mine wired a 10mm 3 core armoured cable to his shed before I got involved and wired it himself already. He wants make it an air bnb...
Evening everyone . Currently looking at pricing a job up . It’s a hot tub supply . Outside socket with a few spare ways in an outdoor cu . 10mm...
Hi guys. It would be really useful to run this past you and get a consensus/input from you for what would be a realistic amount to charge for an...
