B
Brixnmorta
Consumer question here - my property has the old style pull out fuses (property built in the late '80s) and has no significant alterations or extensions to the wiring. Are there any simple tests I should do to establish if the property should be rewired or is safe, especially if I consider letting it out for which it is good practice to obtain an electrical safety cert. Electrical Safety in Rental Property - England & Wales or is the only recourse to instruct an electrician to do a periodic inspection? Visually the wiring appears to be in good condition however I appreciate that there can be more going on 'beneath the surface' and that a visual inspection does not tell the whole story.
