Discuss Homework - low voltage side 3x400V and a short-circuit power on the low voltage side 95MVA is powered by an OPS in the Electrician Courses : Electrical Quals area at ElectriciansForums.net
Hello everyone please help me with this homework which is too hard for me due to the fact my teacher didnt teach well so i have some problems with this schoolwork.
a distribution transformer station with a voltage on the low voltage side 3x400V and a short-circuit power on the low voltage side 95MVA is powered by an overhead power supply 4xAL 70mm2 (aluminum) with a length of 2.5 kilometers. this line is terminated with a switchgear, the component is a single-phase distribution board supplying the circuit of a residential installation with a length of 19 meters, made using aluminum YADYp 3x2.5 mm2. determine short-circuit conditions at the end of the overhead line and pass the expected current at the end of the residential installation configuration. short-circuit current exclusive meters for t = 20 ms and thermal equivalent current during the short circuit Tk = 40 ms
Yeah... nice try but you're a lot more likely to get assistance if you post your best attempt at an answer along with your working out. Even joining the Trainee forum isn't going to to get your homework done for you without you showing an attempt at an answer first.
Reply to Homework - low voltage side 3x400V and a short-circuit power on the low voltage side 95MVA is powered by an OPS in the Electrician Courses : Electrical Quals area at ElectriciansForums.net
Hello, I live in Mexico, where I have a small, un-official trailer park on my property. The property is serviced by my privately owned, 650amp...
I have a 115vac line that tests with proper voltage and will power a low watt bulb but will not run a drill etc... Line from main panel to barn...
Hi All Thanks for your help in advance. I am working on a project to wire a number of low voltage charging units on one circuit. The power will...
So far I have never had to deal with a new supply but a possible site we are looking at will need some major changes and so I wondered if folks...
Hello. Just a lowly homeowner here who is beginning to panic after a major house renovation regarding relocation of the main supply cable to the...
