Discuss Honeywell accenta g4 in the Security Alarms, Door Entry and CCTV (Public) area at ElectriciansForums.net
I have an accenta G4 system which haven't used for a couple of years and the bell box only sounds for a few seconds once activated then turns off.
It works on bell test and the internal keypad sounder works ok but I can't find anything in the setup which would suggest anything wrong.
Bell delay set to 0
Bell timer set to 1t minutes.
Any help would be great.
Hi thanks
No I haven't checked the bell box.
At the moment I'm working on an assumption that it worked before and that it's not now so I would have to check.
I'm about 80% sure it didn't used to do this as it used to go off if we had a power cut and the other week we had a power cut and it rang for 5 seconds and then stopped with just the strobe working for hours.
Hi thanks
It could be the bell box battery going dead and not enough juice to ring sounder
Reply to Honeywell accenta g4 in the Security Alarms, Door Entry and CCTV (Public) area at ElectriciansForums.net
Good evening! Don’t have a huge deal of experience with fire alarms but having to work on a conventional system at the minute with various...
Having to wire around a messed up output for a month or so. Some sort of program corruption is keeping the central lubrication system from...
hello all, I have a Honeywell Galaxy G2-20 burglar installed in my home (about 9 years old). Recently I got a Battery Miss fault showing on...
6K
Our old Friedland chime all too often now emits a only faint "ding"- because the person at the door (usually a delivery driver) just "dabs" at...
I have just installed a Honeywell Accenta G4 system. All ok apart from 2 queries: The entry/exit zone 1 is a PIR (there are no door contacts on my...
