A
akprincehbd
hi,
yesterday I just noticed my horstmann economy 7 timer not working... I tried the boost (1 hour) button, it still can light up on the indicator and heat up the water tank. However, when I used the Timed dial to set the time, I turned the dial a whole circle it won't heat up the water also the 'timed' indicator won't light up. the switch is not in 'off' position
I'm sure before I was using the timed dial in the day time and it also works, even it's in the day time, when I turned the timer dial, align 2am with the winter marker, the 'timed' indicator will light up. but now no matter how I turn it , it won't light up, the boost function works fine...
does anyone know what's the problem inside?
I have other concern, I was using all day same price tariff. but the elec power company said will switch me to the night cheap (E7) tariff at some point. Is it because they change the tariff?
thanks for your reply !!
