Discuss Hot Tub Colours in the UK Electrical Forum area at ElectriciansForums.net
A
asqs342
Hi all,
I have just got given a hot tub which i am installing. A friend of mine has put in all of the SWA to the area into a termination box and ran this all the way to a new 32 amp breaker within the CU. This all happened prior to the hot tub getting delivered and while i was sorting out the base for it. I am more than happy with terminating the swa from the hot tub and glanding etc but when i have stripped it all back the colour scheme is not what i was expecting. 3 Cables as follows:
Grey
Black
Brown
The question is: How do these relate to the standard line, neutral and CPC???
Really confused and any help would be appreciated. My sparks friend is on his hols hence i am not asking him.
Carl
I think i have just answered my own question. Just clicked that it is 3 core. It is a Sunday!!!!! If anyone could confirm it would be much appreciated.
I know this is obvious , but i take it you are making the terminations back at the board as well and your not just assuming the sparks that is on holiday has made them off this way ?
I know this is a daft question but as they say , theres nowt so daft as folk sometimes !:goofy:
I do hope you are not relying on the MCB as the only device to isolate it, you should have an isolation switch accessible outside.
One other thing, if you are more than capable, you really should know what the harmonisation colours are!
I know what they are , just sometimes I cant tell them apart lol.:innocent:
Has it been connected within the DB? If so it very much depends on what way your electrician has connected them in there. How is the circuit protected? Also, I thnk someone has already pointed out that you want an isolator local to the hot tub.Personally, I really think you should leave this to the electrician to sort!! Good luck either way.
Many Thanks for all of your input. Yes it is connected at the DB on the RCD side. He has just turned it off. There is an DP Isolation switch outside where the SWA from the tub goes in to allow external iso. He is going to come and commission it on Wed on his return. He is NAPIT. Many Thanks again and BTW job done and all working well.
I did a Part P course some time ago so i conscious of the rules and dangers involved.
Not trying to be a smart arse with this observation but it did make me laugh ,
" he is going to commission it on Wed ", but then you say "job done and all working well " !
Sorry, but how do you know it is working well? Surely, you would not try energising it before all testing has been completed?
This is not a piece of kit one should simply switch on and say "looks good to me".
Honestly not trying to be condescending, but you really should have waited for your electrician to connect this if he is the one testing and signing it off.
Once again thanks for your advice. I can assure you that this is not going to be used until it is tested. When i said job done and all working well - i forgot to explain fully that my wife and children weren't literally in there enjoying themselves and sipping champagne but the power is there.
I am now removing myself from this site as when you ask for advice you just get sarcastic and smart arse responses which really isn't in the spirit of forums. Those who have helped - thank you, those who haven't, well nothing else more to say.
Good day to you all
Yet another chancer ! See you latter's that is if we don't read about you in another tragic accident in the nationals first !
Sorry to the mods if you don't like my comment , but at the same time this meant to be a forum for ELECTRICIANS !
EDIT ; Just had a quick look at some of his past post's , this joker will end up doing someone before he is through " my electrician is on holiday " what in fairy land !!!!!!
Something needs to be done about people on this site lying to get advice !
Be honest in the first place and then we would know to start from the basics and not jump in with advice that could be fatal if taken by someone of the wrong skill level / base . :disappointed:
Reply to Hot Tub Colours in the UK Electrical Forum area at ElectriciansForums.net
The earthing arrangement where the hot tub will be installed is formed in the TN-C-S system. I want to install the sub-main distribution circuit...
Hello there, I have a sub main in a small bunker that is supplied from an in house 50A supply that then supply’s a 6mm2 SWA that supply a small...
I'm starting a new project on Monday, new dental practice conversion from a shop. Nothing new here, customer doesn't know what electrical heating...
Getting desperate to clear my small garage, and I have a bit of old red/black T&E. I used a few bits to add a socket or two in my flat and a...
Hi, I'm trying to rewire an old plug. I've rewired a few in my time, but all have been with the post-2006 wire colours. I have this old welder...
