Discuss hot tub installation advice in the DIY Electrical Advice area at ElectriciansForums.net
Carl Alvey
Trainee
Hi guys, im having a hot tub delivered in the next few weeks. the hot tub is 32a and will need a 40a rcd from my consumer unit to an outdoor isolator then to my tub.
Ideally id like to install an outdoor socket aswell.my consumer unit is an old steepler one using series e and the largest breaker i can get is 40a.i was thinking of coming from main consumer unit to an outdoor unit which will contain a 40a for the tub and 16a for outdoor socket and ensure that i dont use socket whilst tub is being used??? up untill a time when i can get main consumer unit changed enabling a larger breaker to be fitted.
Would this be ok or would it be better to still install outdoor unit but forget the outdoor socket for now.
Any thoughts and advice would be appreciated.
cheers
Ask your spark to make sure the cable and outdoor unit are suitable to add a socket when your upgrade is done
and buy shares in your energy supplier. them things cost about £30/week in leccy.
Do you mean RCD or MCB (or RCBO?) The circuit will need overcurrent and fault protection, usually provided by an MCB, and the hot tub will almost certainly need RCD protection.
Remember you also need to size the cable for a larger OCPD if you plan to increase it in the future. And you also need to pay careful consideration to the earthing arangement of the suply and how to deal with this at the hot tub.
Op ... The only sensible advice is employ a spark to do it properly ...
And this falls under part P too
I will be getting a sparky to do this but thought id ask advice so that know if i get told right info by someone
Reply to hot tub installation advice in the DIY Electrical Advice area at ElectriciansForums.net
Evening everyone . Currently looking at pricing a job up . It’s a hot tub supply . Outside socket with a few spare ways in an outdoor cu . 10mm...
The earthing arrangement where the hot tub will be installed is formed in the TN-C-S system. I want to install the sub-main distribution circuit...
Hi, I have received conflicting advice about Main Isolator Switches and would appreciate forum member's help to plan a way ahead. Looking to the...
Deleted member 155212
Evening Gents just after a bit of advice and what would you do differently. I have wired up 3 kw heaters in 4mm tuff cable (40 meter distance...
Hi Guys So I've never installed a hot tub supply before so take it easy on me. I've spent a bit of time researching it myself and its a minefield...
