Discuss hot tub in the Canada area at ElectriciansForums.net
H
homesafe
Ive got a hot tub to wire one day this week,it requires a 32amp circuit and it is about 20meters from house,should i just run a 4.0mm armoured from the crabtree starbreaker to a IP65 rotary isolator,and then just use some armoured flex from that to the hottub,:eek:
Just a couple of things I guess you would have thought of.
Obviously the circuit will need RCD protection, either from a shared incomer, if a split board, or an individual RCBO. If you are going across a garden be careful with your cable routing, garden forks will go straight through SWA (another reason for the RCD). No problem with the local isolator but if you have any SWA left over why not connect in with that or if not possibly SY. Remember to include for outdoor glands in your price.
Good luck, and remember to take your overalls off before you test your work:eek:
And don't forget, the steel wires on the swa are a consductor for the e f l path, AS well as the cpc(16th ed,sorry, what was the 17th term for the cpc?)
Reply to hot tub in the Canada area at ElectriciansForums.net
Replaced our old 240v hot tub with a new one, which also uses 240v for motors, heater, etc, and 120v for low amp LEDs and touch screen control...
Hi Guys So I've never installed a hot tub supply before so take it easy on me. I've spent a bit of time researching it myself and its a minefield...
Upgrading the Hot Tub to a Swim Spa, current power for the hot tub is 6mm 3x core swa to a 40amp mcb and 40amp rotary isolator. Cable is clipped...
Hi I am thinking of putting in a Hot Tubat the end of our garden, fed from the a garden shed, more or less next to it, now this might be a silly...
I would like to set up my hot tub wiring a few months before my tub arrives, I would also like to do it DYI. The run I'm panning is 100' from the...
