Discuss Hotpoint Oven SA2 540 HIX with Clock Fault and F12 Fault in the Electrical Appliances Forum area at ElectriciansForums.net
I have a Hotpoint SA2 540 HIX with possibly 2 faults
The clock keeps going to reset mode and the display sometimes shows F12
The F12 clears if I turn the oven On then Off again.
The clock reset is an annoyance, however if I have Auto On set it will cancel it out.
Any Ideas?
Reply to Hotpoint Oven SA2 540 HIX with Clock Fault and F12 Fault in the Electrical Appliances Forum area at ElectriciansForums.net
Hello All. I have a Westinghouse pxr6988 wall oven. It has a cutting out problem when using it in Keep Warm mode, it heats ok and stat is working...
Hi all, There's 2 single fan ovens in the house my mother recently moved into. Posh elecronic AEG units. It's been sat empty for a year, so the...
Hi Our oven stopped working suddenly including the clock. It was on the fan oven setting at about 150 degrees. I checked the fuse board - it had...
Hello, I’ve got an issue driving me crazy and can’t get anyone to figure it out as it’s not their issue. We had a new extension, single rear...
I'm writing this mainly hoping something occurs to me while writing it! I got called to an occasionally tripping RCD. It's a Hager double height...
