Hi,
I have to quote to provide a circuit for a hot tub outside. Could you let me know if what I plan to do sounds okay?
So from a 30ma RCD and 40A mcb there is an existing 10mm2 twin and earth going to the garden through conduit approx 20mtrs from the board. It is PME system. From there I had planned to install a rotary isolator 2 mtr from the tub, some 6mm2 swa to the terminals. The hot tub can draw 12.6kW.
I really appreciate your help.
thanks
thanks
