Discuss House Alarm keeps going off in the Security Alarms, Door Entry and CCTV (Public) area at ElectriciansForums.net
W
wannabesparky
My Mothers house alarm keeps randomly going off, sometimes in the early hours of the night, and on the panel it always shows Tamper lit up.
Whats wrong with it and what can i do? im not familiar with alarm panels much so only sensible answers please.
The Panel is an OPTIMA XM6 with 6 zones on it.
The tampers should be wired in series check you have continuity through all the circuits or you may have to go and check theres no loose connections through out the circuits, not that many and not to hard to do.
yeh could do that or just link the tamper terminals in the board from what i can remember the signal wire thatsets the alarm off are normally closed so if sum1 cuts the cables it would trigger the alarm anyway hth
Reply to House Alarm keeps going off in the Security Alarms, Door Entry and CCTV (Public) area at ElectriciansForums.net
Hi, So I'm trying to understand what's going on with my off-peak electricity supply, as something's wrong with it and I'm trying to determine if...
optima xm6 alarm internal sounder has gone off and highlights tamper on the control panel. I have tested the battery with a multimeter which shows...
Hello, I am renovating a house. I am rewiring myself. I am getting an electrician to install a new consumer unit & test all my work. I'm looking...
My burglar alarm went off last night when it wasn't even set. When I went to Keypad it was showing TAMPER with a Red light. I could not silence it...
13K
