Discuss House consumer unit to garage consumer unit in the UK Electrical Forum area at ElectriciansForums.net
Hi all
I’m planning to install a consumer unit in my garage. The unit will eventually power a 32amp hot tub, 2 double sockets and a small lighting circuit.
The distance from the house CU to garage CU will be about 10m. I plan to run single cables through 20mm steel conduit under my concrete drive once I cut a channel which will exit in the garage.
1. Is it advisable to run singles or T&E through the 20mm conduit?
2. What size cable is preferable (10mm)?
3. What size RCD/ RCBO should I use in the house CU to supple the garage consumer unit (50amp)?
I am an ex electrician who has been a naval engineer for 12 years now so I’m confident I can complete the work myself. Any advise/ comments on my 3 questions would be really helpful. Thanks
Stick to your day job
Reply to House consumer unit to garage consumer unit in the UK Electrical Forum area at ElectriciansForums.net
I wondered if it is OK to have 2 x Main Switches in the same consumer unit. One feeding the RCBOs in the House and one feeding the CU in a garage...
Hi all, what is the best way to configure surge protection in domestic dwellings when you have multiple consumer units? Does each consumer unit...
4K
Hi, just helping someone out and apologies for the long winded post. Would like install a couple of weatherproof double sockets on the patio. 1...
