Discuss House has a lean to with a metal clad box and plastic double switched socket adjacent to a waste water drain. in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
A lean to with a metal clad box and a plastic double switched socket fitted to it adjacent to a water drain for a washing machine. Obviously I am not happy with it so thought I would fit a BG weatherproof IP66 as a direct replacement; thinking I had to remove the flex I pulled some 2.5mm T&E through the wall.
Then I got to thinking, does this existing circuit conform to any version of the regs.
But I think it might be better to upgrade to current regs perhaps.
My questions are also what is required to do that?
Does it require mechanical protection through the cavity/wall?
Can I use a flexible cord or T&E? Already pulled T&E through.
Does the socket require an isolator - if so what type and should it be located in the House or Lean to? If in the lean to I would probably use weather proof and include built in RCD - although not yet decided about a CU upgrade and installation test and certification
And will want to add some lighting in future - current lighting is unclipped flex with plug!
without some pictures, it is hard to understand the comment "Obviously I am not happy with it"
it is possible with the info provided for it to be either ok to current reg's or not compliant with them or some previous ones.
Your profile shows you have a full tech certificate, is this correct.
I have what's on my profile?
[automerge]1592337255[/automerge]
Well I would never put a plastic socket on a metal clad box.
Being adjacent to the drain there is a possibity of getting splashed.
As for passing t&e through the back knockout of a socket through the wall might well conform to previous regs.
What other info do you need to be certain?
Have a look, click on @800ABusbar
What is the problem running T&E from the back box through the wall? Are you referring to the less than 50mm depth rule?
Does it conform to previous regs
Does a spur double socket in the lean-to conform to previous regs? By that I am referring to the original installation.
Reply to House has a lean to with a metal clad box and plastic double switched socket adjacent to a waste water drain. in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
Hi all, hoping everyone has enjoyed their bank holiday weekend. I hope this post goes in the right place as I've just joined. I'm looking to swap...
  • Locked
5K
