Discuss How do I get my meter with 2 related meters changed to a single meter with 1 MPAN? in the UK Electrical Forum area at ElectriciansForums.net
Tim25
I have 2 related MPAN's which I'm being charged for but I only have the 1 meter, how do I go about getting this changed to a single meter with a single MPAN.
I've been told an electrician needs to check that the one supply is enough to supply my property?
Thanks!
Who told you this?
It does seem the correct advice, as I did it for a client recently... But his involved combining 2 supplies into a single supply...
Sorry I meant 2 related MPAN's, so that would be the same? I want to combine these 2 to one supply. My energy supplier told me, but not sure what exactly I'm asking for
Guessing that the property has an off peak supply & a 24 hour supply? Have storage heaters been removed/what's the current arrangements for heating the property & providing hot water?
Sounds like a previous owner had some renewable energy systems under the RHI scheme. Maybe change your tariff? Usually these schemes provide quarterly cash incentives for seven years. Do you have a heat pump or biomass boiler or something? It may be that the scheme is still running or could be renewed, are you sure you want to get rid of it?
I had 2 x DB’s on different meters tariffs however recently changed to one meter single tariff. Just called Eon and they sorted it. Now changing provider to save money. Hope it works out for you.
Reply to How do I get my meter with 2 related meters changed to a single meter with 1 MPAN? in the UK Electrical Forum area at ElectriciansForums.net
Hi everyone, a landlord is converting a house into two flats and wants a separate consumer unit for both flats upstairs and downstairs. He also...
3 Phase Smart Meter EDMI ES -30 B Install I have a question regarding the potential replacement of my existing EON supplied ELSTER A1140 3...
Good day readers, if any,I am an old sparky, a very old sparky. I can remember old Faraday giving us lectures Wednesday evenings at evening...
I live in a flat in Scotland supplied with an old 2 meter system called THTC where one meter using a time signal supplied heating and hot water...
