Discuss How do you do it in the UK Electrical Forum area at ElectriciansForums.net
the pict
Mentor
A persistent ballache, Joining T&E to SWA I have tried various methods and all work, metal enclosures, wiskas, butt joints , henlys in boxes , is there a way I have not thought of ? a resin enclosure with a flat end and a round end, and please if you cant think of something do not resort to puerile slagging, you are not 14 and on facegram or instabook
for small stuff...upto 6mmm, i always use a wiska box or similar. bigger cables would be henlys in a suitable enclosure. occasionally done a soldered joint with heat shrink inside the property. if i was working in america, i would, of course, use fire wire nuts.
Cheers I have a issue with a 10mm T&E installed by the builder through a stone wall its getting changed to SWA dropping from the attic "eventually" I just need to get it connected for a campsite bothy to allow the job to progress a bit
10mm you need decent connectors in a box. i can only recommend henleys.don't think wagos will cope.
I like resin joints, you can usually cut the end of the shell to suit the shape of the cable. Then seal it up with putty/ deso/ whatever. Remember the shell is just there to hold the resin until it sets.
Yeah thats an idea and I have one in the van cheers I will sus it out tomorrow
If it is going to be inaccessible, resin joint every time, but like the OP have tried various methods!
Doesn't have to be a conventional underground joint kit a wiska or similar filled with resin will do!
Reply to How do you do it in the UK Electrical Forum area at ElectriciansForums.net
I've always disliked needing to wrangle three 2.5mm T&Es into one 13A socket. The three solid cores rarely sit cleanly, and there's always the...
5K
For various reasons out of my control, we have wound up in a situation where we have 1.5mm SWA cables buried in these pillars and exiting out of...
7K
Hi all, Merry Christmas to everyone, and apologies for talking work during the holidays😅 I have my first EV charger install job early in the New...
So a quick catch up so you can get an idea… I was asked to do a job for another electrician, as he is too busy. I’m busy myself but said I’d...
  • Locked
5K
