Discuss How hot will the modules get in the UK? in the Solar PV Forum | Solar Panels Forum area at ElectriciansForums.net
M
mark_
Hi there,
Do any of you experienced chaps know what would the likely maximum module temperature would be in the uk? I am just checking the compatibility of various modules with an inverter and have hit a snag. The panel i have selected works fine until the max temperature goes over 35 deg C. I would guess that module temp would be in excess of ambient temp but Im not sure by how much. Of course I dont want to install something that wont work when it gets too hot but on the other hand there is little point searching for a panel which works up to 75 deg C when we are very unlikely to ever see such temperatures. From testing our panels before installing I have never seen one above 25 deg c but then I would expect it to rise considerably when installed with the sun shining on it all day.
Your thoughts would be appreciated.
I'd say top end would be around 65deg to be safe, but it's going to be pretty rare to get above 55-60. I've definitely done installations where the panels are too hot to touch for longer than a few seconds, so reckon those numbers are about right.
they will definitely go significantly above 35 degrees though.
Reply to How hot will the modules get in the UK? in the Solar PV Forum | Solar Panels Forum area at ElectriciansForums.net
Doing a cable calc for college and need to know the ambient temperature of this circuit - Supplied from a board inside where the ambient temp is...
Calculate the temperature rise in a system consisting of six conductors carrying 1500 amperes each at 132kV, insulated with XLPE, and spanning a...
NICEIC Certification Scheme Getting accredited to
Looking for some advice regarding joining a CPS. I've been in the electrical industry in various roles for nearly 10 years. I started my...
Now Ive done Periodic Inspection and Initial Virification Qualifications with LCL/EAL (so non C&G 2394/95) # strange part building Modules , this...
I have a Firebird oil boiler that is controlled by a Honeywell timer (no thermostat) that has channels for hot water and central heating...
