I’ve been looking at ammeters to install in my car, I see an analog gauge by Bosch that shows -60 to +60 amps which would be great most of the time to show when my car is charging, when it’s fully charged, and how much of a drain is on the battery when the engine (and alternator) is off. But when I think about the battery and the CCA’s required for start, I wonder if this gauge would be okay? And how it protects itself if it does. There was no mention of a shunt with this gauge so I’m not sure exactly how it hooks up.
Then I’ve looked at digital screens that show volts, amps, and sometimes a few other things. These normally come with shunts rated for 100 amps or 300 amps that hook directly to the negative battery post and inline with the main negative wire, but seemed to be geared more towards solar I think. And then I wonder if those shunts could handle the high amperage of a car start over and over, and I don’t believe they will since they’re not rated at a high enough amperage.
It’d be neat to find something that shows milliamps all the way up to 1,000 amps and records peak amps. Especially with out spending a fortune.
