Discuss how to cure a blowing fuse in the UK Electrical Forum area at ElectriciansForums.net
G
Guest111
Some latvian contractors had complained about a welder blowing a fuse on an extension lead repeatedly,Finally they announced they didn't need the electrician calling out as they had resolved the issue,yes that is a piece of an M6 bolt!
God they could of atleast jammed an m8 in there and done a proper job
not just the euro trash that do this, plenty of fencing contractors and farmers are experts in this line of work
yeah they let the magic smoke out
you know when they do this type of **** they deserve the darwin awards:90:
most welder manufacturers specifically state that extension cords or leads must not be used.
actually some appliances are coming out with fused plugs and gfci.
dont get me wrong tony I agree with you and i wish we had fused type plugs like you guys use
but I have to work with what we have.
this is also the reason my home is wired for low voltage control (only outlets are at 120 volts)
all lighting and switching is at 24 volt.
also solar cells charge the battery banks for emergency lighting
the side benifit is a lot lower cost in wire
my statement about earning a darwin award is for those who would replace a fuse with a solid bar.
fuses are made to burn out if the current draw is exceeded this is a sacrificial safety element.
purposely bypassing a safety device be it a fuse or safety switch is just asking for problems.
Fault finding I replaced a 450A fuse with a solid link, so the back up was a 1200A ACB. After many abortive tests I’d run out of ideas. Found the fault, a tree falling over on fire gave the game away. Its roots had broken an UG joint.
I don’t recommend this normally but needs must at times.
I’ve done it a few times on 11KV (upped the protection relays first) to give a good short that could be traced. Wandering around fields in the middle of winter isn’t my idea of fun.
PS I've never work on domestic.
Do you leave that to the professionals Tony?? lol
You come in to my world. I'd leave you (for) dead!
In fourty years I've done five domestic installs. I had my arm twisted for them (bloody family + wife). I stuck with what I was comfortable with.
Best five jobs of your life?????? I Doubt it, and anyway.....where you part P registered?? If not, then your not qualified!!!!...........(i'm being extra cheeky to my elders now)!
You've got a thanks for making me laugh.
Betters, no. Yes we're electricians but in different fields.
I haven't a bloody clue about domestic. But I'll ask do you know the M&Q or Foundries acts?
Horses for courses springs to mind.
My idea of running a cable wouldn’t involve chasing a wall. I’d just demolish it, run the cables through and the brickies would rebuild the wall afterwards.
You think I’m joking, I walked in the plant managers office and told him two 240mm3½c SWA’s were coming straight though his office. It was cheaper to relocate him than divert the cable.
OK I’m an animal, but its how my life in heavy engineering made me. I couldn’t do you’re job if my life depended on it.
Reply to how to cure a blowing fuse in the UK Electrical Forum area at ElectriciansForums.net
Hello, Is there an actual age limit on house wiring that would prevent a traditional fuse box being replaced with a consumer unit please...
I'm delighted to announce that some time in the next few days / weeks, BBC Breakfast will be airing a short piece about MEET (The Museum of...
5K
I'm having an extension built and the builder leading the project has said that the electrician will be over in about 4-6 weeks to start his works...
NAPIT Certification Scheme Fraudulent EICR, who to contact?
I hope somebody can help me here, I really need some advice on who to complain to in this situation please: Hello, So after months of chasing my...
6K
