Discuss How to get power? in the UK Electrical Forum area at ElectriciansForums.net
Hello Everyone
I am trying really hard as a homeowner to learn as I go and just want to do the right things.
I removed this from an older treadmill and I am trying to get it to get power. I want to use it for a halloween prop
I unhooked the motor speed controller from it and just want to figure out what from this photo I need to wire correctly for power.
Thank You very much.
OoOoo not sure if that's the sort of thing somebody would need in their hands to work out.
Have you tried a 12v battery to test? If you get it wrong then you probably won't kill yourself maybe? LOL
Biggie my recommendation is to try getting power from another, that’s an old motor it’s just fan cooled and not fully closed. Them textile motors are all like that get a TEFC motor
Reply to How to get power? in the UK Electrical Forum area at ElectriciansForums.net
I recently purchased a rural property in Arizona. The property receives power from APS, the local electric utility. Power arrives from the...
hello , Just a note to see if anyone been in the same sort of journey as me? I wanted to retrain as an electrician at 40 and on bad advice did a...
Looking for counsel / guidance to replace an original Dayton On/off with speed control switch. I’ve checked with a couple local electrical supply...
Hello, novice diyer here, but trying to learn more about electrical. I have done some basic wiring but that's about it. I have one of those...
Has anyone taken apart their & self repaired it? 2013 Dodge Grand Caravan SXT - Mileage: 112223 - DTCs - P0480 cooling fan. Also codes in TIPM...
