Ive recently moved in to a rented property and am unhappy with how high the bills are. Im trying to figure out why - the property is a two-bedroomed flat, two people occupying, everything is electric, storage heaters and horstmann economy 7 quartz water heater. I'm sure we're using the storage heaters correctly because ive used them before, but im not sure about the water heater. the water heater is switched to 'timed', and the time is set correctly, and to wintertime, which is correct. But is it left on or should I switch it off at the wall during the day like I do with the storage heaters?
