Discuss How to wire a elster 3 phase generation meter. in the Solar PV Forum | Solar Panels Forum area at ElectriciansForums.net
M
mikemack00
Hi chaps,
Tell me, is a 3 phase elster generation meter wired the same way as a single phase, i.e the inverter cable on the left and the supply cable on the right of the elster 3 phase generation meter. Make sense?
As with any 'Generation Meter' , treat the Generator (inverters) as the Supply and the incoming mains as the Load.
Is it a direct wire or CT meter?
Reply to How to wire a elster 3 phase generation meter. in the Solar PV Forum | Solar Panels Forum area at ElectriciansForums.net
Hi there, I built a house with ground source heating 5 years ago and it's a fairly large house so I have 3 phase supply 80 amps per phase. I had...
3 Phase Smart Meter EDMI ES -30 B Install I have a question regarding the potential replacement of my existing EON supplied ELSTER A1140 3...
I have been asked if I can wire a motor for a car lifter in a domestic garage, however the motor is 3 phase and only single phase is available in...
I have a single phase stainless steel pasteuriser that has two control boxes attached to it. One box houses the control for the electronics and...
I didn't get a picture so will have to wait until I go back again but I've done a crude drawing of what was there. Its in a commercial set up...
