Discuss How to wire IKEA light pendant in the UK Electrical Forum area at ElectriciansForums.net
Jen Jackson
I bought an IKEA light pendant and confused about how to wire it. The light is controlled by 2 switches and I have old colour wiring. From the ceiling I have 3 cables coming out. One is a single red cable, the other 2 contain black, red and earth.
The switch I have to put these wires into only has a neutral and a live hole.
Should I group the neutral and live cables together?
Many thanks in advance!
Hi Jen,
The first few replies will tell you (politely I hope) to get an electrician to do it, as that is the correct advice as there's a bit more too it than just 'grouping cables together'. Then however, someone who is too eager and maybe bored will explain how to do it without going into enough detail (as there is so much more to it than joining the correct wires together) and your light will work albeit in perhaps a dangerous fashion.
Good luck :)
Jen, I would suggest that you call a local electrician tomorrow and get them to do it. Obviously check their cost beforehand, but for this type of job I charge my basic callout charge which covers the first hour. I would guess it will cost around £50 to get an electrician out, but at least it will be done properly and safely.
Jen, also be VERY careful what you touch, as I assume you have no test equipment to prove dead. There is a situation commonly referred to as a "borrowed neutral" which in simplest terms means the wires you think are dead because you've switched the breaker off for say "upstairs lights" aren't all dead as a neutral is energised from another circuit. Call a sparks and be safe!
Jen - Firstly you need to be able to understand a loop-in wiring system. this would solve all your problems. you cannot blame the ikea light!!! as any double insulated light fitting will have a connector like that one. this is an example of the sort of thing you have come across here:light.jpg
That looks like an old style two way switching system. The single wire is the switch line. It was how things were done prior to 3C &E cables coming along. It’s done the same way as doing two way in singles.
I recommend getting a good (old) electrician who remembers it.
Oh dear, should have marked the switch live before you disconnected all of them, without a decent voltage tester you are going to struggle
Reply to How to wire IKEA light pendant in the UK Electrical Forum area at ElectriciansForums.net
Hi everyone, We have bought 2 new low-hanging light fittings from Ikea to go side by side above dining room table to replace the single pendant...
Hi all was having a problem with lights work one min not next took ceiling rose cover off to find a stray black wire only terminal free is the...
