- Reaction score
- 0
Just need some help on how exactly to setup the wiring for this
Discuss How would I power 3 GU10 LEDs from one plug (power cable) in the Electrical Forum area at ElectriciansForums.net
Im presuming that this has to do with your table stingy-ma-bob...
Are you fitting a switch or just using the switch on the socket( if it has one)
Do you have the lights?
Wire to Live, Neutral & Earth (if earth is needed) to first light, then to second, then to 3rd.
I'm not the best with electronics, so if you don't mind being more detailed, that would be super helpful. I understand what you mean but I don't want to make any mistakes. I believe this will be wired in series?
The forum doesn't allow step-by-step instructions to be given out.
Google 'wiring lights in parellel diagram'. This should give you a better idea of what you can do.
Okay. Will do. Will I need to add resistors? And what about the ground wire from the mains?
Reply to How would I power 3 GU10 LEDs from one plug (power cable) in the Electrical Forum area at ElectriciansForums.net
