Discuss How would I power 3 GU10 LEDs from one plug (power cable) in the UK Electrical Forum area at ElectriciansForums.net
Im presuming that this has to do with your table stingy-ma-bob...
Are you fitting a switch or just using the switch on the socket( if it has one)
Do you have the lights?
Wire to Live, Neutral & Earth (if earth is needed) to first light, then to second, then to 3rd.
Got to get the rotating table going mate......
I'm not the best with electronics, so if you don't mind being more detailed, that would be super helpful. I understand what you mean but I don't want to make any mistakes. I believe this will be wired in series?
Obviously I'd have to get some GU10 sockets first right? Any specific ones?
The forum doesn't allow step-by-step instructions to be given out.
Google 'wiring lights in parellel diagram'. This should give you a better idea of what you can do.
Okay. Will do. Will I need to add resistors? And what about the ground wire from the mains?
This is basic wiring knowledge mate. I'm with @westward10 on this and think you should get someone in to help you with this.
Mains voltage can be dangerous.
Reply to How would I power 3 GU10 LEDs from one plug (power cable) in the UK Electrical Forum area at ElectriciansForums.net
Done a job yesterday, remove old 12v halogens and replace with mains, gu10 downlights. Fitted some LED gu10's no issues. Got a call today saying...
Hi All, We have an old Country villa in Spain. The housing electrics were not good so the house recently has been completely re-wired to a good...
we just replaced our hot water tank with hot water on demand (natural gas) and still have the old power run for the tank which is 30a 240v. I...
Mobile home outdoor power supply is a pedestal that power to the mobile home plugs in much like an RV. The main power supply into the mobile home...
