F
fd3typer2
Hi,
I'm installing complete systems for a small development of 11 flats and would like to know what the recommended way to setup the earthing arrangement. This is what I'm doing and what we have:
In the hallway on the ground floor there is a newly installed Lucy head (I think thats what you call it) supplying 12 boards with red solid blocks with Line and Neutral.
The earth is a single large cable bolted to the side of the Lucy head.
I am fitting Switch fuses in metal enclosures. 25mm tails hanging out for the meter guys, and 16mm SWA load side going up to each flat. The 3rd core in the SWA for the earth I have left long and it passes unbroken through the enclosure and out the bottom.
Should I have the earth blocks on each board connected to the DNOs earth with 16mm g/y or should I do it another way?
Cheers
Cheers
